The edge is where it makes connection so its the edge... least in mine which has to be kept clean, centre where one pin makes, contact edge the other. Suspect our trusty dealers wear gloves.
I dont use a knife as per this video but a thick headed screwdriver and twist. A bradel to get it to ping out. The guy uses a screwdriver his finger to catch it. This was 2025, same as 2032 edge connectors make the contact so its the edge that needs to be kept clean and the bitter bite sticker removed off the surface if stuck on.
I guess a cheap exhausted battery if a replacement doesn't work. Vag use Panasonic as James pointed out. I use Duracells bought from Amazon main store not their market place seller options.
AI told me to avoid Duracell as they have an extra thin layer of bitter bite coating (plus the sticker) which may somehow reduce the conductivity and shortening the battery's useable life.
Oh, and the new Graphene layer (not graphite). Now I am using a new CR2032 with Graphene technology which is specifically designed for use in key fobs.
The "Superconducting" Matrix: Adding a layer of graphene to the internal electrode structure. Because graphene conducts electricity incredibly fast, it lowers internal resistance and ensures a steady, powerful signal even when a device is far from its receiver.
Other major brands like Duracell, Energizer and Panasonic still stick with using Graphite only in their dated designs.
Remarkable what AI can tell you... probably Chinese battery manufacturers. You just give the surface a wipe on your shirt if you think there is bitter bite remaining.
& that's the edge connector you said they dont use.
I think its in the paper stuck on rather than sprayed across the battery.
thanks everyone, at the beginning I tried 2 times and correctly checked if there is no protection
I've just tried another time by being more careful not touching the edge, checking for any dust or something & cleaning up surface, and this time everything works normally :)
On another topic, I choose the Varta brand after seeing an interesting video from a French youtuber, it shows that there is a lot of bullshit marketing and it's not always worth paying extra money.
1,5 year with the original one is nice too, I don't drive on daily basis.
I hope the subtitles are accurate
Reactions: Momochi and Tell
I did have an issue with my Nvidia remote control that takes the same batteries. I concluded the voltage was too high on new batteries :(. Swapping back to the old it worked... dah. I've now changed the remote control to a Chinese Nvidia copy that takes the pencil cells (the tube style remote for people familar with the Nvidia that takes the pencil cells). Another variable but I suspect that car fods aren't so sensitive to batteries putting out too high a level of voltage. Threw a lot away on that basis when I needed a new remote.... design fault on that.
BTW you can use iso propane to clean connections with a cotton wool bud or white spirit for when conventional batteries leak. Former takes off grease.
Extra money.... Don't know how to define it.
The "Graphene-technology" battery I put into my key fob 2 weeks ago cost me 15p each. Yes, £0.15 for one. Hope it is not extra money 😅😅
I've had to renew wiper blades that were only about a year old. Maybe Cupra don't fit the best quality 'consumables' (wiper blades/batteries/12v batteries, etc) to new vehicles?
I'm on my second set of wiper blades in 18 months (this time I replaced the rear one too)
As for battery - mine went at about 9 months... I was stranded in the works car park and got in the car but then nothing. I went home in my van and grabbed the spare and got back just as the AA turned up and he replaced the battery in the fob cos he said he sees this everyday with KESSY systems so keeps a dozen batteries on board for such incidents.
Reactions: trew
I use the Bosch ones (blades) on my Ateca. Now the Ateca and Arona they haven't closed down the ability to use the "voltage" coding method to shut off stop / start. Formentor you can't unless you replace the switch so the story goes. All that stop starting stresses the battery. MQB Evo they stopped you using the coding method to neutralise SS. I'd never remember to press that button... but now drivers of the MQB Evo do a lot of pre flight switching. It would drive me nuts.
Yes always carry a spare with Kessy. Its got us on cold days when you arrive somewhere but can't lock the car since the battery fails in the cold once taken out of the house. Then you can also get the one when you cant get in when its locked. Hence the need to have a CR2032 tucked on your person. Got me in a ferry queue which wasn't good as one was blocked in the line of queue. Social media mates said carry a spare... they were more upto speed than me at the time.
Reactions: Cupra Jon
Exactly why I run a BURTEQ memory module on mine.
Remembers :
Stop/start position
Lane guidance position
Drive profile
No faffing around switching them off every time I get in the car.
Just start up and drive with the settings I last used.
Reactions: Tell
Remembers :
Stop/start position
Drive profile
This thread:
Not sure what they do for EVs... except you dont have stop / start. Lane assist on the original Atecas you could turn it off and it stayed off. By circa 2018/19 it was a coding job. By 2020 the lock down commenced to stop you doing anything via coding. SFD2 2025.
@East Yorkshire Retrofits have their own solution. Probably on their website. Pass on the differences.
Someone told me the auto start-stop by VAG is handled by the 48V mild hybrid battery, while the 12V one is just for the cold starting plus the infotainment and external/internal lightings etc, thus frequent start-stop while driving (including restarting the engine after being switched off during motorway cruising) will not drain the 12V battery.
Someone told me the auto start-stop by VAG is handled by the 48V mild hybrid battery, while the 12V one is just for the cold starting plus the infotainment and internal lightings etc, thus frequent start-stop while driving (including restarting the engine after being switched off during motorway cruising) will not drain the 12V battery.
Pass on fangled hybrids... I know James doesn't like them. Non hybrid its stressing the battery but then I got a big heavy duty diesel battery. Hybrids are just a half way stage to full EVs. 48V battery charges the 12V so it depends whether the 48V battery is used for the starter. The original Honest John one was that hybrid drivers were not doing the mileage when running on battery only, so the 12V battery never got charged and became flat. So messing with the way hybrids work you give yourself a problem. They are suppose to manage these parameters themselves now so you don't fiddle with the automated settings.
I have had a failed starter motor in my driving career... bit of a let down when it happens getting stranded at work. Probably for that reason both our cars have stop start fixed and it was quite dangerous in outer London M25 roundabouts to find that when you wanted to pull away quickly to get in that gap you can't... will it start, won't it start. Some people twitch the steering wheel to keep the engine running.... their solution....
I believe the auto stop-start function will be suspended if the 48V mild hybrid battery is depleted, thus you won't be stranded at traffic lights or roundabouts.
Other ways to manually suspend this function are switching to Sports mode in your DSG while in stop-and-go traffic, or switching on the A/C. Both will drain your fuel tank instead, especially for the thirsty EA888s 😅😅
