Hi All, Have had the V1 Raval for a month now and all was going great up until this morning when the dash lit up with warnings and car won’t move.
Just called Cupra assistance and technician on their way this afternoon so will see if they can fix it or take it away to dealership.
Was originally running 6.0 and had one warning about 2 weeks ago stating Engine fault, go to dealer. This went away after a couple of restarts and dealer told me to ignore it and keep an eye on it.
updated to 6.0.1 over the air a week ago and all was good until today.
Will update what happens next.
I have a video of this but can’t see how to upload it, might be of interest to others.
Just curious, have you enabled the option Low Voltage Battery Protection in the app that keeps 12V battery charged up by the bigger battery if voltage drops, just curious if it might help avoid this issue. I know 12V battery can be very sensitive to giving all kinds of faults, had lots of those cases with my 12V battery in my Mazda 3 when only driving constantly very short distances, have to keep it charged with a maintenance charger overnight roughly once a month to avoid errors. I know with my driving habits I better keep the low voltage battery protection enabled on the Cupra at least, especially with how much interior stuff there is in the Cupra Raval that I assume is connected with the 12V battery it might drop fairly quick if you frequently do short trips only.
Reactions: Charlie9900
Just curious, have you enabled the option Low Voltage Battery Protection that keeps 12V battery charged up by the bigger battery if voltage drops, just curious if it might help avoid this issue. I know 12V battery can be very sensitive to giving all kinds of faults, had lots of those cases with my 12V battery in my Mazda 3 when only driving constantly very short distances, have to keep it charged with a maintenance charger overnight roughly once a month to avoid errors.
Precisely my thought. I have the 12V battery protection enabled since July, but not sure how efficient it is at keeping it charged. I do a lot of short journeys, like 90% of my usage.
So yes, I suspect my ADAS alerts are due to a low voltage of the small battery. I might use my trickle charger indeed to check if that takes care of the problem.
Thats interesting, it is not enabled.
Is there any reason not to enable it or why it wouldn’t be by default?
Thanks for your advice.
Well the only negative aspect it drains the bigger battery a bit faster even if sitting idle you might end up charging the car a bit more frequently. But seems like a common consencus among Cupra communities that this option would be best to default to "on" rather than "off". Especially in the case of Raval which is their smallest / most city focused of all cars that typically also means more frequent cases of "short trips only" use cases, if you frequently drive longer trips then it doesn't matter if it's enabled or not.
Ok, really not worried about using a bit of battery as the car is charged at home most days.
Am I correct in thinking there must be some sort of alternator connected to the drivetrain that usually charges the 12v battery.
Seems an odd way to keep the 12v topped up.
Can't speak for how it's done in practice as I'm no expert there but I know most EVs do charge up the 12V with help of the bigger battery, with some exceptions here and there some earlier models didn't like the very old Nissan Leaf to mention one example. It varies though if it's done only meanwhile driving or also when shut down, this setting in the app makes so it also happens while it's turned off. If you only do frequent short trips only, charging while driving won't be cutting it in the longer run. The voltage will slowly drop which also used to happen to my Mazda 3's 12V battery (and more noticeable consequences during winter, had it happen twice that the car would no longer even start, I've once replaced the battery, this other time I let them charge it at a dealer with a more powerful charger as the maintenance charger didn't have strong enough power to really get it out of the low voltage state no matter how long it sat charging)
So update, VW assist called out and all warnings gone and back to normal!
The technician said this often happens with various VW Audi cars and this was the first Raval he’d seen, so was probably just a software bug that reset itself by being switched off and left for a couple of hours.
He cleared all the codes and sent a report to head office so they will see if more similar cases occur leading to a possible recall or update.
I have activated the Low battery protection anyway, so will keep an eye on it.
The Computer also flagged up a recall for the front seatbelt anchors to be checked which I’ll get booked in for.
Must say the roadside assistance is great and thanks to all of the advice.
12v battery charging - the 12v battery is charged via the HV battery through the on board power inverter.
12v battery protection mode - checks the 12v battery once a day for stationary periods of up to two weeks and charges it up to what the battery monitoring system sees fit (likely 12.6v). Emergency charging is triggered if the voltage drops below 10.6v
After 14 days of the vehicle being stationary the system check drops down to once a week.
I spoke to Cupra about the 6.0.1 not fixing the ADAS false alerts. According to them, there will be another update in November which will take care of that.
In the meantime, when this happens again, they suggest to turn the engine off, let it rest 15 minutes for the memory to reset, then start again. All the alerts should disappear.
Yesterday I restarted one hour later and it worked. So next time I charge it, I'll try the 15 minutes rest.
I didn't speak with them but reading here that's what i figure out :)
everyone talks about the 48 week famous new software update delivery that would fix it (6.0.1 and 6.0.2 are mostly some sub version to try fix some more dangerous issues that would totally fail or some security thing)
Also everytime it happened i just left the card and let it lock and go back don't even had to wait more than 1 minute and mostly worked (only took more when the dashboard was completly back and that was just making the car impossible to drive, luckily was at night so in morning was fixed but again it's mostly leave, lock and unlock the car and working again --' )
After a week with the car i already know everytime i enter to ride there's a 50% chance it will just give a lot of alerts include some purporlser thing and yet it then works normally just start driving (sometimes the ACC dont work if i just keep driving with all those warnings so if i have time i will leave and enter and if not i just go as is)
I get 5% chance it would not even work and need to leave and enter again :p
If i just finished charging to 80% it's then 100% chance i need to enter, start, park, leave, enter, start again before the next ride lool
All percentages are a funny thing to put it :)
Just to clarify, the alerts of faulty ADAS only appear when starting the engine right after a 80% charge when charging slowly from home. No problem if I charge up to 60% from home, or if I use a public charger up to 80%.
Happened again this morning and did the IT special of switch if off and on again after 15mins.
Came good but not ideal having to do this at 5:30am.
There’s a reason I’m departing at that time so another 15mins then makes me late for work.
Will switch on the 12v battery charging again to see if that helps.
*The 12v battery charging was already ON so who knows!
Yes, it's annoying, version 6.0.1 is not fixing the ADAS faults at startup after a charge. I got a call from the dealership two weeks ago to let me know a new update was due this month and to keep an eye on the notifications. So far there's no new OTA update available.
I had another update yesterday, that's the second one. Will need to check the number as didn't notice what it said
What kind of charging speed did you use to charge your Raval to 80%. At least I didn't experience it yet, I set my home charger to 12A / 75% of its speed capability.
I tend to leave it at 10A, sometimes 8A if I have big appliances running like dishwasher, washing machine or the air-cons.
I will try 10A next time, just to see if happens to be related to how much current you use / how long it keeps charging. I will need to try optimizing my charging time eitherway so it's a bit closer finished to the morning when I leave for work so battery is a little bit warmer.
Reactions: vicalva
