a) In my oppinion the Engine have incorect coding.
Can you tell me why is changed Engine coding byte 5 from 24 (Front Assist) with 74 ?
Adresse 01: Motorelektronik (2D2D2-DLAC) Labeldatei: Keine
Teilenummer SW: 05C 906 032 J HW: 05C 907 394 D
Bauteil: R3 1.0l TFS H01 2363
Revision: 42101001
Codierung: 0125001223 24 0D0810000000000000000000000000000000 genuine
0125001223 74 0D0810000000000000000000000000000000 actual coding
Betriebsnr.: WSC 31414 790 00200
The right coding is
0125001223 64 0D0810000000000000000000000000000000
64 means (ACC FtS or ACC S&G)/ DSG with ESC High.
1. 2Q0 614 517 AQ ESC_high coding is ok for DSG + ACC (10009002, 10009003, 10009007, 10009008).
2. What exactly causes FAULT_ESP_CONS_ACC? - ACC incorect coding.
3. What causes SCL_ACC_Anhalteweg_Error in the ABS? - ACC incorect coding.
4. Is FAULT_CODING_RADAR_POWER_REDUCTION definitely a wrong coding bit in address 13, and does anyone know which coding setting controls this? Here is neccessary to check if in Adaptation, Radar_power_reduction: 38
b) Address 13 (ACC) is necessary to be analized separately.
Thanks a lot for your help.
The incorrect coding in 01-Engine had already been found and corrected previously, so that part was already OK.
The remaining problem was indeed in Address 13 – ACC, specifically the Radar_power_reduction adaptation channel.
After correcting this adaptation, the errors disappeared and ACC / Front Assist are now working correctly.
Thanks again for pointing me in the right direction!
Reactions: serdar_18fr
Here is the complete Auto-Scan after the successful retrofit of ACC + Travel Assist with KLR steering wheel.
Everything is now working correctly without ACC / Front Assist / Travel Assist errors.
Maybe the scan will also be useful as a reference for others doing the same retrofit on an MQB-A0 vehicle.
VIN: WVWZZZAWZ
Chassis Type: AW-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 44 5F 69 75 A5
VIN: WVWZZZAWZ Mileage: 25300km-15720miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (2D2D2-DLAC) Labels: Redir Fail!
Part No SW: 05C 906 032 J HW: 05C 907 394 D
Component: R3 1.0l TFS H01 2363
Revision: 42101001
Coding: 0125001223640D0810000000000000000000000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM10TFS03005C906032J 002015
ROD: EV_ECM10TFS03005C906032J_002_VW27.rod
VCID: 261402A0A86A2CDABDC-8072
VINID: 9E69EAAAA467AA09400091C2086C253339
No fault code found.
Readiness: N/A
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 051 G HW: 0AM 927 769 N
Component: GSG DQ200G2_M H07 1909
Revision: 00007009 Serial number: CU502207057204 CVN: 4129AFC2
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021.rod
VCID: 3A2CC6D04CD2B83AE94-806E
Address 03: ABS Brakes (J104) Labels:. 2Q0-614-517.clb
Part No SW: 2Q0 614 517 AQ HW: 2Q0 614 517 M
Component: ESC_high_vFGS H34 0362
Serial number: 08507940200212
Coding: 0A034B64154150B6D203A81834DC22A649124D06226A245844541555452C44659248B2604456241A222AA8AAA269D64BFF966BD2FF242424242424
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
ROD: EV_Brake1BOSCHESPMQBA0_005_VW27.rod
VCID: 7DA60DCC1D7C4F028C6-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Component: VWKESSYMQB 037 1400
Revision: 00037000 Serial number: 0601876371 Dataset Number: V03935330VL 0001
Coding: 132C0C0723
Shop #: WSC 31414 790 00200
ASAM Dataset: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB_VW27.rod
VCID: 48C8AC18023EDAAA6F0-801C
Address 08: Auto HVAC (J255) Labels:| 2GN-907-044-V1.clb
Part No SW: 2GN 907 044 HW: 2GN 907 044
Component: Climatronic H24 0106
Coding: 012000000800010001100801024401150110000000000000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ACClimaBHBMQBA0Touch 001008
ROD: EV_ACClimaBHBMQBA0Touch.rod
VCID: 7F5AF7C417705D129EA-802A
Address 09: Cent. Elect. (J519) Labels: 2QX-937-BCM-V1.clb
Part No SW: 2Q0 937 090 E HW: 2Q0 937 090 C
Component: BCM A0 Std+ H12 0963
Serial number: 01102211800437 Dataset Number: V03935379HB 0001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BCMA0 208001
ROD: EV_BCMA0_207_VW37.rod
VCID: 3430E8E86EB64E4A338-8060
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: SBY22M08D31H10M23S44
Coding: 0018DD
Driver door control module:
Subsystem 2 - Part No SW: 2Q1 959 405 E HW: 2Q1 959 163 D
Component: FHSG_DRV 002 0003
Serial number: 00000000000062540505
Coding: 130007
Front passenger door control module:
Subsystem 3 - Part No SW: 2Q1 959 406 E HW: 2Q1 959 164 D
Component: FHSG_PSG 002 0003
Serial number: 00000000000062511251
Coding: 098007
Left rear door control module:
Subsystem 4 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000062069452
Coding: 030000
Right rear door control module:
Subsystem 5 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000061972268
Coding: 1B0000
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000150058322197 Dataset Number: V03935352CF 0001
Coding: 8471151911
Shop #: WSC 99999 999 12345
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 53F28B74CB7869720A2-8006
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Component: ACCCONTIMQB H09 0396
Dataset Number: V03935397VH 0001
Coding: 30057F4A48FF8748949F812581508700000000000000000024
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 73B22BF42B380972EA2-8026
Address 15: Airbags (J234) Labels:| 2Q0-959-655.clb
Part No SW: 2Q0 959 655 AS HW: 2Q0 959 655 AS
Component: VW22Airbag 020 0411
Revision: -------- Dataset Number: V03935354QR 0001
Coding: 88CCCCC0800000035C5400CF000C40FC0065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 0E445A0020DA449A65C-805A
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 442 063 105 22
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y51990675962E2FH
Coding: 2D2D2D
Crash sensor for side airbag: passenger side:
Subsystem 2 - Part No SW: ----------- HW: 442 060 706 22
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y509B093FEA2E46U
Coding: 2D2D2D
Crash sensor for side airbag: driver side rear:
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 208 22
Component: SideSensor_Dr 1C7 0148
Serial number: 3517710B50A419E37428
Coding: 2D2D2D
Crash sensor for side airbag: passenger side rear:
Subsystem 4 - Part No SW: ----------- HW: 442 0B0 507 22
Component: SideSensor_Pr 1C7 0148
Serial number: 3527714BB0979343B14G
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 442 131 507 22
Component: FrontSensor_D 290 118A
Serial number: 355AG83AAC8B82D351AE
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 2G0 920 320 B HW: 2G0 920 320 B
Component: KOMBI 524 6220
Coding: 0424001865840008000866421000000000600400
ASAM Dataset: EV_DashBoardVDDMQBA0 001048
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 1B622354E328E132122-804E
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 E
Component: GW MQB High 524 5502
Serial number: 19072211603627 Dataset Number: V03935391FG 0001
Coding: 030900346F08570023100258180F00010001270000000000000000000000
Shop #: WSC 00400 123 61029
GVL: 01443C0000000600C08080008000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
Generator:
Component: 5-00-14-00-04
Multi-function steering wheel control module:
Subsystem 2 - Part No SW: 3G0 959 442 AE HW: 3G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0120
Serial number: PR6-0440036060230321
Coding: 2D0A00
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 2Q0 915 181 B HW: 2Q0 915 181 B
Component: J367-BDMBOSCH H03 2012
Serial number: 102AA39D
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H10 0021
Serial number: 22000168978011
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 313EE1FC91A47B6258E-8064
Address 44: Steering Assist (J792) Labels:| 2Qx-909-144-V1.clb
Part No SW: 2Q1 909 144 AB HW: 2Q1 909 144 AB
Component: TRW_G4L_MQBA0 613 6050
Serial number: 03251179CB4N250 Dataset Number: V03935378KZ 0001
Coding: 010000000100000001010201010001000000010101
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: 72BC2EF05422007AE14-8026
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G1 035 820 B HW: 3G5 035 820
Component: MU-O-ND-EU H57 0883
Serial number: WG8LGM070922000 Dataset Number: V03935377MY ER01
Coding: 22700000000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_001_VW27.rod
VCID: 1F1A1744F730FD12FEA-804A
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5NN 919 605 B HW: 5NN 919 605 B
Component: ABT_Std-2_Nav 381 8304
Serial number: VWZ6ZHA2351828
Data carrier:
Subsystem 2 - Part No SW: V03 959 817 SM HW: -----------
Component: EUR 2022/23 --- 7065
Serial number: --------------------
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H0 907 383 C HW: 5H0 907 383
Component: Anhaenger H12 0058
Serial number: 000000000006526
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001012
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 2E04FA80809A649A45C-807A
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 H HW: 5WA 035 284 B
Component: OCUGen3High H20 0311
Serial number: 0000000207VIXFF Dataset Number: V03935446GK 0001
Coding: 022700001968A8009005460161002607
ASAM Dataset: EV_OCUGen3High 003021
ROD: EV_OCUGen3High_003_VW27.rod
VCID: 4BC29314134831B2422-801E
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1401
Serial number: EA1567404222030 Dataset Number: V03935410VR 0001
Coding: 00000890115E4020089E00001020002000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW27.rod
VCID: 3634D2E078CA5C5A0DC-8062
End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.1V)-----------
---------------------------No fault code found.----------------------------
