greggyt94
8
8
I bought this car about two weeks ago, and did first major journey in it over the weekend, approx. 350 miles each way with another 100 or so in between. I filled up before leaving and had no issues on the outward journey.
But the next day I was driving on the motorway and started to have an issue where the car would suddenly start to decelerate. I was using cruise control at the time set to 70 and it slowed very noticeably to about 64 before it felt as though the engine kicked back in and it went back up to 70, this then kept happening at seemingly random intervals but quite often (sometimes 2 mins, sometimes 5 or 10).
I tried turning cruise off but had the same issue, and this time I found that there was no response from the accelerator and it continued to decelerate lower than it had previously. I found that I had to tap the brake to get it to kick back in, as soon as I hit the brake and went back on the accelerator there was a response and I could go back to speed. This issue hasn't happened driving around town or at low speeds generally, I'd say it seems to only occur at 50+mph.
On the return journey I experimented a bit to see if I could find an issue, but the only thing I really noticed was that when it started decelerating, the fuel economy would go very low, down to about 13mpg before it kicked in again and the fuel economy recovered too. In general I would also say my fuel economy hasn't been amazing since the issue began, I averaged 39 on the return journey, doing 70 or lower depending on speed limits. ACT is working normally. After a second stop of the day after about 250 miles, I turned the car on and the engine management light had come on.
Does anyone have any idea what this could be or had a similar issue? Something I read as a possibility for general deceleration problems in cars is a fuel filter problem, this made me wonder as the problem began when my fuel got down to under 1/4 of a tank, this is the first time the fuel had got this low since I've had the car.
I have had a look around and not found anyone mentioning this issue, but apologies if I've missed something!
Thanks in advance, and I'll go and get a diagnostics done tomorrow but thought it was worth asking on here.
OK thanks, I'll look into that. Just to note, I actually was on the way to having infotainment system upgrade when the issue started, so it was scanned then and nothing came up, but engine management didn't come on til later the next day
quick update, carista arrived so i plugged in, Basic OBD2 error code is P2177 'System Too Lean Off Idle Bank 1'. Codes under Engine - 17158, 07150, 17132, 12742, 02821. There are some other codes under electronics too 197644, 204290, 204549, 919304
Fuel filter problems I would say are normally associated with Diesels and in winter.
P2177 could be linked to air intake leaks/blockages.
Double check your air filter isn't blocked and all your joints/connections of the intake system are perfect and not leaking and are tight.
Just by way of update several years down the line in case anyone is having a similar issue...
It turned out to be the ABS module (a known issue with these cars I believe), which was just triggering the brakes at random times. The low mpg when it was slowing makes sense as the car was accelerating and braking at the same time. The module got sent off to some company that can repair them and it has been fine ever since. Scans for faults didn't show up anything relating to the issue so that won't help. The car has been incredibly reliable since and never had a whiff of the same issue.
Hiya, had a look through old emails and stuff. The company was BBA Reman which I think is no more.
I went through old emails and stuff and just for extra detail, the timeline of events for me was actually that after posting in this thread, the front left brake got fully stuck on on the M25 and I had to pull off and manage to limp to a friends house. He ran some tests and it was showing up the following fault code, so that did flag the module as the problem:
0213 - Vacuum sensor
C10A3 29 [008] - Signal Implausible
[Single Vacuum Pressure Sensor sends no valid data]
Intermittent - Confirmed - Tested Since Memory Clear
A huge shout out to AVIT garage in Slough, it went to them once my mate had identified the issue. They helped out a lot with speaking to the dealer who'd sold me the car and fought my corner, and carried out all the work, car has been faultless since it was with them.
Reactions: nd-photo.nl
