Moving rear washer problem
Cupra TDI 150
287
Hi guys
Had a good search but I can't find much in the way of info on this. I have the moving rear washer jet issue, so I have stripped the tailgate and taken the wiper motor out. I've taken the back cover off and the washer jet feedpipe and i'm not sure if there is still a piece of pipe stuck in the spindle. Has anyone had this problem and taken any photos or doeas anyone have a a photo of the repair kit?
Mar 3, 2008
807
sunny Devon
yes i have the same problem sort of ,when you wash the back window my jet only flows at about 2inch of water...
the rest pours into the boot behind seat badge/boot handle.
mine seems to be leaking in that bit of pipe or little black elbow joiner,on the bottom of motor.
i need some help too.
cupra-rich
423
coventry
had this problem a while back, sounds like the copper/brass tube through middle of motor is broke. new motor is one fix £50-£60. or seem to remember there is a fixing kit available,not sure from where though,
Cupra TDI 150
287
Slim sounds like you have exactly the same problem as me, I've taken the back cover off of the motor and the brass pipe has snapped, just needs a replacement brass pipe which i think is the repair kit. Will try to take some photos
Cupra TDI 150
287
Have managed to speak to my Seat dealership today, and asked about the repair i've seen mentioned about £25 gave no description or picture on his system. I then rang my local VW dealer who said there was no kit and it would need to be a brand new motor. Until i gave him the part number of the repair kit, to which he said he could order one as they don't stock it. He seemed a little shocked as I was more informed than he was. Will order one from VW as the dealership is about 10 miles closer than the nearest Seat dealership.
Cupra TDI 150
287
Slim the part number is
8L0 998 711
You should be able to get it from Seat or VW, don't let a VW dealer say you can't get a repair kit like mine did, he soon found it when i quoted the part number. Ordered mine today and is being delivered over night. I've put the motor back in for the time being luckily I did as it's been tipping it down all day. I'll pick the kit up first thing tomorrow and let you know what is in it and take some pics. Mines broken about 10mm from the washer jet.
Cupra TDI 150
287
Found this pic while searching with Google last night,
Haven't managed to go and get my kit yet as it's the wife's birthday so had to make breakfast etc !!! Will try sort it out later
Cupra TDI 150
287
All sorted and installed, however left the boot trim panel off for a couple of days to make sure no leaks. Gonna work on a how to now taken plenty of pics
Cupra TDI 150
287
Slim apologies for not posting pics sooner been flat out with work, where did you get your remap done? I was thinking of TSR in Bridgwater but heard some bad things about them recently
transporter42
how much did the kit cost and is it a lot of work,my copper pipe is broke?
Sep 18, 2009
2,443
Shropshire
think i need to do this also. Water at best manages to get about 2 inches up the rear window and leves the rest of it dirty.
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
i take it you need to remove the rear wiper blade?
Is it just a matter of remove the nut on the wiper arm?
i tried loosening it earlier and it wouldn't budge.... i'll order one of these tomorrow!
MK R BOY
139
Hi Cupra
It would seem a number of us are having this problem, there are about 3 or 4 threads running on this broken brass pipe/leaking washer/boot trim issue and to be honest I think we are trousers down/wet/wind in face kinda territory - myself included!!!
I think we would really appreciate a "how to do" plus some pictures from getting the trim off to ordering the part and everything!! Having priced it up with a new trim plus motor this could stretch into £150 mark so its an expensive mistake to make.
Any help would really be of some benefit if you could find the time.
Thanks for any posts you make buddy.
Lee
jonesy118
388
Cheshire
Nope, you need to remove inner tailgate trim and wiper arm (13mm nut). You then need to unbolt the 3x10mm nuts inside which attach the wiper motor to the tailgate.
On the motor itself there are 6-8 Torx screws, remove these and give the back plate a tug to separate it from the gasket. Re-assemble is the reverse of this. I washed out the brass tube and poked around with a needle and also removed the jet itself to clean.
My brass tube wasn't snapped, but it was leaking during use, so I wound some PTFE tape around the outer tube, up over the top and round again, then pierced the brass tube through the PTFE tape. Re-assembled and it's been perfect for the past 2 months or so. I've left my parcel shelf and boot trim off to keep an eye on it, and it hasn't leaked since :)
Cupra TDI 150
287
Will try to get on it been mad busy at work & applying for new jobs also trying to fit my boost gauge which I had for my birthday back in September please bare with with me I have all the pics which I took while I did it. Again sorry guys
