whats the benifits in putting the D.V backwards?
therench
216
read a post before that said it made a different noice backwords? not tried it yet but if it works fine that way i might give it ago
8bit
3,401
Aberdeen
No idea about the standard item but fitting the 007p in reverse makes a squeaky noise when it opens, you'll need to be using a cone-type air filter instead of the standard airbox to hear it tho.
Try searching for "reverse DV" or "reverse 007", the benefits/drawbacks of this have been discussed at length here.
Pyro
No difference tbh just the noise I'll get you a vid gimme a minn;)
therench
216
pyro are they 2 diff videos? they booth sound same and is that ment to be backwords as it sounds same as mine forward????
Jun 21, 2010
883
Stockton on Tees
on full chat, when you lay off in reverse you get a mettalic chirp and a whoosh, the correct way you just get the woosh, no power gains or anything just a difference in sound, its been said many time but its a marmite thing some people dont like it, i do
Pyro
That's mine in reverse mate I put both vids up coz ones beter but couldn't remember whitch one it was lol witch way it you Vacume nipple facing? Up or to the right?
Pyro
Was off coz we had adjusted the pipe work for a better fit ;) now theres no bits of the bumper poping out :D
Pyro
Yea at bills ;)
Ammo- yea had a few probs with it lol mainly **** clips = boost leaks ;) lol but it's all on there ok now :)
Jun 21, 2010
883
Stockton on Tees
im going to swap it round tommorrow see if can notice a diff in sound then
you will only notice a difference under heavy boost, when you just come on boost and are getting the surge, lay off and it will do it, or well up the revs it will do it too, imagine chucking a marble at a milk bottle its that kinda sound lol:D
