oil leak and breather hose split
gupi_singh
hi, i am new to the cupra engine, i was looking around the engine bay, and noticed a hose was split, searched this up and it was confirmed that its was the breather hose, i noticed oil around this section, especially the dump valve. i taped the breather hose up, untill i order a new hose.
Uploaded with ImageShack.us
gupi_singh
just to add, at mornling start up, its idles at above 1k, at lowers below 1k after a min.
gupi_singh
thanks for the reply, but what do you mean secondary air pump?
i also found some oil below the breather on the top of the geabox
gupi_singh
i undertsand what you meant by secondary air pump sorry about that.
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Probably just leaked down. I'd order a silicone replacement when you can, clean up all oil you can see once its fitted, and see if it comes back. If so, its a different hose leaking
gupi_singh
cheers for the help, will do that, i also been reading up on rocker gasket, something about the seal. But i try the breather hose method first.
