No just that it seems to exist but it has a vnt, my neighbour has the haynes manual for the skoda with the vnt as she thought it might be useful for our cars as they both have the agr engine but I'm not sure if it's a 110 or not. It's the same injectors though for the alh and agr and 1z etc, it's just some automatics have smaller injectors and an 11mm pump but all the manuals have the 10mm pump and .184 injectors as standard. The manifolds are different because of the different turbos but apart from the engine mount on the timing belt end I can't find any other difference, the agr doesn't have the mount there, at least not on mine. If it's just for an engine from the scrappy though then it should be fine as all the manifolds etc will just bolt on, just need to check the mountings.
