Radio not working...
M Bizzle
Hi Guys & gals,
So the other day my radio stopped working in my fr tdi, no power to it whatsoever.
I found the fuse had blown in the fusebox so replaced that, still no joy.
Tried my old stereo... still no joy!
So nipped to Halfrauds today and bought a cheap stereo wondering whether both stereos were knackered (old one had been playing up hence replacement so thought it might've actually finally died) Still... no joy :cry:
Ive tested both the uninterrupted 12v and the ignition 12v on the cars iso harness and both are reading fine on a multimeter however the ground connection was reading 0 resistance.
Does this mean that my ground wire could be damaged somewhere in the loom and the stereos are staying off as a safety measure?
If so does anyone know where the wire goes so I can replace it, or have any ideas where I could run a new one and ground it?
As ever thanks muchly.
xx
Edward9th
276
Dorset
I'd try the unit with the existing (proved) positive and a temporary earth for the other connection. If it works, connect a permanent earth anywhere you can.
8arran8
144
Dundee
I had the same problem for over a week before I realised there is 2 fuses for the radio for some reason!!
I don't have the fuse numbers on me at the moment but can find out tomorrow morning if you still need them :)
M Bizzle
That would be amazing if you could, I've changed 51 but wasn't aware there was another.
:confused:
I've tried running a new earth and still nothing I'm afraid so hoping this other fuse is the issue...
M Bizzle
LEGEND.
thats sorted it!
dunno what was going on with the earth but hey ho.
thanks matey
8arran8
144
Dundee
Glad I could help buddy!!
If you can, then I would just stick with the original earth point, so remove that extra one you added. Unless you soldered it in then leave it :p
MR T
129
7
BOONDOCKS
I too would like to hail you as a legend. Had the exact same thing this morning thought i was in need of a new radio
Feb 24, 2022
13
Hi i have same issue on my 2008 1.9 tdi leon was swapping over standard hu to double din when wire must of shorted out and was left with no power so plugged old hu back in and no power so swapped fuse 8 in engine bay and still no joy does anyone else know of what could be the priblem
Feb 24, 2022
13
Hi thanks for response iv wired head unit up to ignition live from cig lighter but would still like to resolve problem when i refit original hu fuse f8 is ok is there any other fuses??
GORDYDJ
93
11
I have what appears to be the same problem. However, since I was getting power (albeit incorrect readings). I'm a bit confused that I'm getting 12V on CAN- with the ignition off. And just 2V with ignition on. I have checked the fuse (Nr 20 in my case) and it's ok. I have posted in a couple of of different places with no solution so far.
