Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
I used pages on this forum to help me do this fix myself. If you search '6 Dial Dash' or similar and do as much research as you can using those pages you might be able to fix this for the price of a soldering iron. The 'pins' (where one of the electrical blocks plugs into) in the back of the dash appear to be fine, but this is often the problem. This might explain why they couldn't find the fault when you sent it off as they look grand. Had the same (costly) issue myself.
soldering never 100% fixes them, the fuel gauge and temp gauge always show off figures
I had done all that, it didn't work. Sent it off to a cluster repair company but they said that they couldn't fix it so its either new clocks at a dealers or second handers and get them coded
Anyone any idea where you pick up a Ibiza fr Tdi 4 dial cluster ? Looked on ebay but only the 1.8 petrol ones available.
