if you want a remap i have a remapped ecu here.
straight swap and you will have 200bhp!
PM me if interested
HoocH
guess what, went to my local tuning specialist today and he has done a boost gauge test and my car is already remapped and i didnt even know! thought it was nippy! he also sold me a brand new green panel filter for £20! booked in next week for a forge dump valve but still unsure on which induction and exhaust to go for! :-S
How much psi/mbar did you produce?
Should of took the DV away with you and fitted it yourself 5 minute job ;)
thought it was cheap then i can keep it for when i sell the car, it ran upto about 16 he said and usually they produce about 10
Furry ****,
On a std car you should see around 5/6 psi on a cupra R im pretty sure its around 10psi, and on a 'proper' mapped car it should be around the 19/20psi mark.
Sounds like you have a 'mild' map on your motor which is still better than standard :D
Furry ****,
Or a map but with issues?
Might be worth getting the car on vagcom and seeing if any faults come up?
Be intresting to know what 'map' is on there.
sensors are around £75 when giving your old one in to be refurbed, Dan could be right you may have issues with your car hence the reason for the 16psi on the other hand it could just be how the map is.
Dont go buying a sensor willie nillie though as you could just be throwing money down the drain and losing a perfectly good maf. Get it hooked up and see what its doing.
Where abouts are you? im more than happy to scan/log your car if your any where near?
A new maf will cost £65 from eurocarparts with your old one in exchange.
If your still after a dump valve give forge a pm quick as i read they have a split r ex demo model for sale for £100
