The only thing in fuel that will damage an engine/fuel system is water. If there is debris it only gets as far as the filter, if the filter clogs its a case of a new filter and that's it.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
There's a reserve amount in the tank that when reached a 0 mile range is indicated, you can alter the level of the reserve via a Carista or OBDII dongle. I can't remember the volume, 5 or 10 litres I think? I will check later to see what it is in litres. To calculate the miles, convert to gallons and go by your MPG. Actually draining the tank right the way down isn't a good idea, as of the unavoidable dirt found at the bottom of the tank.I have never tried this and I never will because I know it is bad for the engine but I was just wondering. When the fuel computer shows "0 miles" left on Range. How far will the car actually take you?
No, it won't. The pumps in high pressure systems are very well protected. This is another internet mythCause driving with low fuel can damage the fuel pump. Debris and contaminants from the fuel that settle at the bottom of the tank will be sent through the fuel pump finding it way into the engine.
No again. The fuel system shuts down as soon as the engine stops.Yes diesel lubricates the pumps but petrol cars rely on petrol as cooling aid as well as fuel. As the injectors run at a high pressure and temperature, they need constant fuel flow for lubrication and cooling. When an injector desperately tries to inject fuel but receives none, as there is no gas left in the tank, it may permanently fail due to overheating.
Also when you suck up the last bit of fuel from the tank, the thin sediment at the bottom of the tank will travel to the fuel filter and possibly clog it.
Of course this scenario is less likely in a modern/ new car it could still occur from regular occurrence.
Still, surely prevention is better than cure?
Do the petrol cars not cool the fuel pump using the fuel?
They do on some cars and running low can lead to early pump failure.
I don't really understand why anyone would even chance this! It's not much hassle to fill up before it gets so low.
Wouldn't recommend trying this with a diesel. If you run out, a jerry can full of diesel wont get you started on its own. You'll need to bleed the air out of the fuel lines.
Draining it completely can drag some of the settled sediment in the tank into the fuel lines and into the injectors. Never recommended to run a car empty in general
Modern diesels from Mk4 golf / MK1 Leon at least have self bleed systems that allow them to run dry and purge the system.Maybe luck, but, I had to take 5L of Diesel to a friend before xmas who'd run out, it started after around 30/40 seconds of cranking.
Couple of weeks ago I left where I was working to return home, display indicated 35 miles to do a 25 mile trip, with very slow driving 1 mile from my local fuel station it went down to 0. I filled up with 54.5L (first click on pump) into a 55L (Mk.2 Leon) tank with finally finishing at 56L.
No. I put running low because that's what I meant.You mean running out, don't you?
