After reading a few threads about why i get chatter between gear changes am i right in understanding it is not good for the turbo? Because i have tried all the springs from green through to red and it makes no difference to the chatter at all, however the yellow seemed to have a little less chatter. Then i tried reversing the DV (007p) still with the yellow spring and there is no chatter at all anymore just a woosh. Does this sound right?? Will be doing the N249 by-pass next weekend too.
1. Any weird sounds are not good for the turbo. That's why I've fought them for years
2. Reversing the DV was the right step.
3. The spring, by itself, holds the piston / diaphragm
only when not under boost.
4. When the turbo pumps air, the pressure in the large hose (charge pipe to DV) and the thin hose (manifold to DV) are equal, since they are both pressurized by the turbo. Not the spring, but
equal pressure on both top and bottom of the piston keeps the valve closed under boost.
5. When throttle is released, there is vacuum on top of piston and boost pressure on the bottom, and therefore piston is moved against the spring to open and release boost.
6. The fact that in reverse orientation chatter disappears can only mean that with valve in stock orientation it opened too little and too late and did not release air quick enough, while now does. DV006 / 007 needs lubrication to run properly, it can seize, and it's much harder for the air to move it than stock plastic valve, and in stock orientation most of the pressure is taken by the O-rings, which are flimsy. In reverse orientation, boost pressure acted on the bottom of the piston (much smaller surface) instead of side, did not have anything to do with O-rings and aided the vacuum to open quicker.
7. There is a reason for factory fitment: plastic diaphragm valve is much weaker, and for stock boost pressure of 0.8bar is just right. Place a stock valve in reverse and it breaks. Add a twice as large metal valve with heavy aluminium piston and you need air pressure to open in properly.
~Nautilus
