01274 Code
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
hello every one
Just done a scan and this popped up any body know what the problem is
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
thanks in advance :D
sjolliff
Vag-Com, West Yorkshire?
Mar 21, 2010
73
Halifax, West Yorkshire
01274 - Air Flow Flap Positioning Motor (V71): Faulty
Possible Causes
* Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty
* Positioning Air Flow Flap Positioning Motor (V71) blocked
* Positioning Air Flow Flap Positioning Motor (V71) faulty
Possible Solutions
* Check Air Flow Flap Positioning Motor (V71)
o See Measuring Value Blocks (MVB)
o Perform Output Test
o Perform Basic Setting
* Check/Repair Wiring and Connectors
Not sure if its the same on your car, but on a MK4/MK5 golf its behind the glove box.
Can you hear a clicking noise from the area when you turn the ignition on?
Have a look at this thread on how to replace etc:)
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
ahh thanks mate i was doing some research on this earlier but couldn't find where this is on the leon
not to sure mate ill have a listen tomorrow
Stewlcr
did you manage to solve this, ive picked up the same fault....
