Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
i wish flapper the ibiza is mine, and to be fair im not confident at all![]()
suffers from heatsoak really badly im thinking about running with my bonnet off
i wouldn't think that would be worth the effort... the way i see it the car would of been wind tunnel tested, so the bonnet would be an important part of the areodynamics. plus i dont think it will help when you get above 50-60mph
im thinking without the bonnet the gaps/rear engine wall will act like an air brake
hope that makes sense![]()
Standard map rev limit is 6800rpm, so you're car must be remapped with an extended limiter? Custom-Code, for example, extend it to 7200rpm...I can get 68mph out of second gear until limiter at 7200rpm on standard map, could be somthing to do with my 2nd gear refurb (new syncro etc) 2 months ago.
Have you got a boost gauge to see how much boost your runing?
Any other tips to give the man a slight advantage?
Don't allow the engine to heat soak in the queue, keep turning it off if the queue is long.
