Yeah I suspect you’re right there...but worth checking if you have the option just in case.I have been through pretty much every option on the unit and i have never came across it. Maybe i missed it. Will check tomorrow and report back
i do not think boost level will change anyways even with the chip as its fooling the car. The chip will take the cars boost reading, say its 1.7 bar and turns that down to 1.5 bar so the car then goes oh no requested boost vs actual boost achieved is 0.2 bar of boost down. So then the car requests 1.9 bar of boost and then will see 1.7 bar of boost. You are actually getting the higher boost but the car won’t see it as its being fooled.
So in theory the car will still think its stock boost.
i have just taken those figures as an example. Or what i think will happen.
thats if the S box even clips onto the MAP sensor, might just be fuel pressure. Won’t know until it arrives
Thanks for taking the plunge...I really hope it works out and will be following in the big mans footsteps if so!
