1.6 TDI Camshaft sensor location ? urgent
a22tenc
145
Hi, I bought a tmc tuning box and the instructions that they sent were from what i believe to be the 2.0 tdi, which the sensor is in the middle of the engine.
Does anyone know where is it in the 1.6 TDI CAYC engine ?
Also I noticed that there are one plug on each end of the fuel rail, does anyone know which one is the correct plug for the box ? I believe it is the same one as the dtuk so if anyone has a dtuk box please tell me.
thank you.
ibizamk5tdi
21
I hope it's not for the cam sensor which is a bitch to get to! The sensor is located on the exhaust cam pulley, you can only see the end of it, the wire then goes thru the cam cover and is plugged in under the inlet manifold, nearly smack bang in the middle.
Sent from my SM-G935F using Tapatalk
