100% Dead Toledo :-( Electrics?
tolly16
Hi all, newbie to the forum so greets to you all!
I have a big problem, I think I've killed my Toledo (1.6 petrol job).
It's not been used for a few months and was very damp inside (floor pans etc, same old story of leaks). The battery was dead so I connected a charger with a quick start facility and tried to start her up. As soon as I switched on the ignition a number of things happened:
The CD player fried..smoke came billowing out of it and it sizzled a bit..
The dash panel made strange clicking noises, light flashed, the LCD readout went nuts and...
Now everything is dead. No dash, no start, no electrics at all :-(
I've checked all the fuses that I know of (dash panel and on battery) and they all seem fine.
Thanks for any advice or hints in advance.
D
tolly16
Thanks Nathal, Nope didn't check, didn't even know about it :), but I'll have a look tomorrow.
Also think I'll check ecu power relay after searching a bit more on these forums.
Thanks again Natal.
D
tolly16
Never overlook the obvious..
Couldn't get it sorted unfortunately so called out the car sparks....
They changed the battery and it all fired up :redface: could not believe it!! Felt like a total prat.
There was power getting thru when I connected the charger at first, (blew up the stereo after all) and dash was lit, so there you go...
...don't rule out the obvious is the lesson for me.
