105 tdi starting issue
teeth2k
908
sussex
Hi
Can anybody shed any light on what to check
1.9 tdi 105 engine
New glow plugs
Taking 5-6 turns before it comes to life, no smoke
I have looked about but cannot work out what to check first
lleiro
65
If it does it consistently a battery going bad or the starter are always the usual suspects.
Sent from my SM-N930F using Tapatalk
lleiro
65
Also the glow plugs are worth a check
lleiro
65
See if you can try a different battery
Bony
26
Berkshire
Have you had the car scanned for codes? Think I've read somewhere the glow plug harness can be problematic although vcds would be my first move.
Sent from my Nexus 6 using Tapatalk
teeth2k
908
sussex
ok ran 2 scans
first with dash command and fault read as follows
p0401 exhaust gas recirculation "a" flow insufficiant detected
second with ross tech and got
012295 camshaft position sensor (g40) no signal
p3007 000 intermitant
minimarvel
38
ESSEX UK
Our105 tdi altea would not start at all recently. Diferent reason to yours though (wires corroded)
Google search your fault codes and check on other forums for similar starting issues and same fault codes found. Your engine code is shared in lots of other platforms, you won't be the first person with this fault.
Does read like your cam position sensor needs replacing or there is a wiring fault with it though.
Good luck and report back with your progress please.
teeth2k
908
sussex
After trying to find the various gaskets for the clean and not being able to work out which ones I needed iv decided to order myself a dark side egr delete
minimarvel
38
ESSEX UK
Your read fault code for Cam sensor then in your next post said that you have bought a crank sensor. They are not the same thing.
You may have to get your ECU software modified to delete the EGR not just a hardware mod. Google your engine code. Others would already have done it.
teeth2k
908
sussex
Silly question but what's the difference, I put my reg into euro parts and that's what I found,
Iv purchased HAAS Camshaft Sensor
Just my luck it's the wrong one!!!!
And yeh I understand I will need a remap, something I will look into but not really looking for a map for more power
SeatJay
293
I swapped out my EGR for a new one (70quid) at the weekend and its made a big difference. its only one Gasket you need the others are rubber seals between the Anti Shudder Valve(SP?) and the EGR to manifold. If you just take the ASV off you can get really good access to clean the EGR with a tooth brush and you wouldn't need to mess with the gasket on the side...
teeth2k
908
sussex
Egr delete arrived today, fitted and found the car to be a lot more responsive. While fitting I found the cam sensor unplugged, plugged back in and car would not start, unplugged and car started so I guess that's faulty.
