JJ_arosa
vag com give me these codes
16487 P0103 Mass or Volume Air Flow Circ High Input
17968 max engine speed exceeded
i aint been over 120mph on provate road :S
this mean my maf has gone again ?
keeps losing boost aswell have to reset ecu with vag com all the time.
possibly maf or lambda
iv had in the past 2 weeks bank one 02 sensor plus it fails on vag com, could this be due to it being de-cated and 2.5 inch allway thorugh or u think its the lambda packed up?
iv also had it running lean on vag com but then seem to clear its self so faulty lambda ?
have you still got both lambdas connected in the engine bay? it still needs both plugged in to create a circuit, but if its decatted aslong as theres one there unless the wiring was broken it shouldnt matter as it isnt reading anything.
still have the two mate and im 99% they both in the exhaust will double check, so as long i got one in the exhuast the other just sits in the bay wired up ye ?
well if you're decatted you'll not need to worry about b1 s2 as its the post cat, if it was b1 s1 then its likely the pre cat is on its way out.
Is your map ok with a decat? Or did you do the decat after the map?
since map phill its had full exhuast system turbo back as it had a sanderd one with cat, filter now i the wing, also iv done the boos bypss and fitted the reistrs an removed the cai
it was mapped on a standerd set up part from it had a ko3's turbo fitted and a cheap air flter, got reciept of cc stage 2 and also rung them up and the chap knew the car and pevious owner
ye good thinking lol best get myself booked in then for a map what u wrekon phil
been to garage today and both my lambda sensors are in my exhuast so shall i take the one after the cat out? and leave it danlge or not ?
heard that you can put spacer on it so you can move the sensor more out.so not so much of the sensor stick inside exhaust
