Hi Guys,
Not having a good time with my car lately seems everythings going all together (new battery 2 weeks ago), I have a MK1 Leon, last weekend the engine light came on, Cars running fine however seems fairly low MPG at the moment.
So I've ran VAGCOM and faults are as follows.
Engine 16786 EGR Excess flow
17566 pressure sensor
CAN gateway 01314 ECM
I can print VAGCOM results if required,
I've cleared the codes and the engine hunts when idling. After running up and down the road a couple of times, code 16786 comes up again however now when idling it's absoulte fine, and under readiness EGR is Passed. Yet when the fault code is cleared it's False/Failed.?
After about an hour the engine lights comes back on.
I have also had EPC light come twice over the last few days however clears after the ignitions switched off.
Then today the Oil light flashed and beeped three times, So I pulled over and checked. Went to Halfords and brought some Oil just in case, topped up a bit and carried onwards on a stop/start journey, came on a few times during various parts.
So I checked the Oil from cold, only to find it's sitting on 3/4 dipstick level, added a little more.
However still lights up, after checking the manuel to see if it was Oil pressure, it says something like these symptoms the car should not be driven and contact dealer.
The cars currently not been used
just collecting snow, but i'm not to sure where to start? Any idea's.
I really need to find a solution.
