No I'm pretty sure there 14 x 1.5 thread.
And unless you already have a set of tapered bolts you'd need new ones as OEM are radius head.
I'd also be very surprised if you got 6 full turns using a 10mm spacer with standard length bolts :)
yes i've got to get new tapered bolts. The original studs had about 20mm of thread available once on the original wheel to screw in. With the new wheels and 10mm spacers it has about 5mm of thread available to screw in. Ive got the rears on ok without spacers but don't like the way it sits and don't really want a narrower wheelbase at the rear so will use spacers on them too, just need to get 16x 12x1.5 40mm tapered studs and 4x locking wheel studs.
will need to check the 12mm or 14mm diamaeters
little pic with the back wheel on. Rear is looking abit high but suspension hasnt settled from jacking it up as i havent moved it.
yep, got my 10mm alloy spacers, just waiting for the 14x1.5 40mm tapered wheel bolts, then i need to get 4 new Goodyear Eagle F1 Asymmetric tyres (no change from £500 then :()
