__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
So finally got my laptop sorted and vag-com installed. Im hoping to go out on a logging session this weekend. Im hoping to get my logs posted up for the guys in the know to tell me if my cars as it should be. I have a k03s with all the goodies with revostg2 installed and i was hoping sombody could tell me wht blocks i should measure so i know if i should crank up the timing via the SPS3. So if sombody could could post the blocks up and also what the block actully is that would be great!
Cheers!
002 020 115 118 should pretty much cover things.
4th gear, one block at a time imo from low down rpm to redline.
Just bear in mind 4th gear redline is 120+mph....
Cheers Phil, im going to try and log her either today or tommrow and get the results posted up so i know weather to adjust me boost via the SPS3 for the JKM RR day :D
Cheers for the link big lad, i had already downloaded that to my PC but was alittle unsure what to log in relation to changing my settings.
Cheers :D
