1st service..
mr_claypole
may the farce be with you
ok, car has 8k miles on it, but its a dec 04 register.. i picked it up last july (05) with 50 miles on.. so as far as i'm concerned, the car is in effect less than a year old.
however, just gone in for its first service as the aircon isnt cold anymore.. the guy that picked it up said it would probably need regassing...
should i expect this to be done under warranty - should the aircon need regassing every 8k miles or year and a half? seems a little lame to me..
also, those with mk4 cupras - how long have the brake pads lasted??
cheers
James
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
sometimes a stone from the motorway can puncture one of the thin metal aircon pipes and cause a leek
if thats the case then its not under warranty
muddyboots
Still hanging around
Oct 16, 2002
5,739
Only if it's on a Welsh motorway though.
:runaway:
muddyboots
Oct 16, 2002
5,739
Correct.
It's the cause of the leak that will determine if it's under warranty or not.
Ric 2001
Need an ID-ten-T form
Done 9500 miles and the fronts are fine, discs are smooth, but the backs... thats a different story, they've been squicking at around 7000 miles and have got very deep grooves in them.
And they look like they have been sitting in a feild getting rusty. Want to change to tarox discs and pads, but need to find out if they'll fit or not.
Also the issue of the brake discs/pads seems to be quite commom issue across the range.
