2.0 TDI CAGA vibration
Aug 23, 2019
Hi every one!
I have (2011) EXEO ST Sport 143hp 2.0TDI CAGA engine. My question is about engine vibrations amount you can feel at gear box shiftier and steering wheel at idle. I can`t stand! Do I have any problem with DMF or motor mounts. Visually motor mounts are in good condition. I did test vibration spectrum with phone app and I can see
that vibration frequency is approx 27Hz = 2nd harmonic of 830rpm. Probably those vibrations are normal for SEAT if we try to compare with Audi B7.
Aug 23, 2019
Thank`s Caldi for info.
Actually here in Latvia are not so many Exeo`s. So I don`t have any chance to compare. Any way I feel
vibrations more on right wing and bumper if you touch them. Also I can see a bit vibration of Bixenon projector at right side (car is LHD).
Probably I will try to change right side motor mount (car have 230tkm). Another vice car starts and pools like rocket
Aug 23, 2019
Small update!
Finally I did change hydraulic motor mounts and there is improvement - less vibration and motor sounds quieter. Left motor mount was totally
leaked hydraulics oil (red residue underneath) and right side just started to leak.New motor mounts I choice OEM because with aftermarket
there usually is problems with vibrations!
