Ibiza Cupra
1. Is my clutch Hydraulic as i thought they were but my dad said it looked like it was cable???
If it's hydraulic where is the fluid bottle, how do i check the level??
2. How do you change fog light bolbs????? Got the black cap off then i was stuck!!!!
Thanks Guys.
yes its hydraulic clutch, i think its the same reservoir top up as the brakes, not entirely sure about the fog lights though.
See i was telling my dad it's hydraulic but then he showed me the cable???? I dunno.
Trust me, its hydralic. just been through all the gearbox stuff, still doing it.
For the for light bulb, go behind the bumper and twist a cap thats behind the fog light. its a bit tricky to do, deffinatly a day time job and if you can get your head in there (jack the car up) its alot easier.
Yeah i know you were having trouble wit yours! Hows it all gone???
If i have any gearbox/clutch questions i'll pm you as you must know everything there is to know!!!
I got the cap off, Just couldn't figure out how to get the bulb out!!!!!
I might take it out all together and get a Cold air feed in there.
Gearbox is done YAY!!!!!
Just gota do the flywheel now which is finaly agreed with what i heed.
I think its kinda a metal clip/spring doobry which is tricky to get and think mine went ping accross drive way, hence the daytime job.
If you can feed the air filter from it than yeah why not.
