2005 Altea 1.6 Keyfob VCDS Problem - not pairing.
  • Thread starter Deleted member 105879
  • Start date
Oh no... not another keyfob question :lol:
Got a pre-loved 2005 Seat Altea 1.6 petrol and am trying to iron out few electrical glitches in the car. Have tried pairing the 1 remote fob key that came with it to operate central locking. New battery installed, red light flashing.
Methods tried:
1. Tried the trick where you take out the lock barrel and operate the lock with flat screw driver - it acts as a second key. Did not work - Youtube tutorial might be useful to other members of this forum - youtube search Programming Volkswagen Flip Key FOB remote with only one key in real time.
2. Using my VCDS i tried this tutorial - youtube search How to program mk5 VW remote key fob keyless entry using ross tech VCDS , did not work either, tried few times, clearing all errors and saved keyfob values before each try.
Sorry not allowed to post links yet - new member.
During VCDS pairing the car does not flash indicator nor does it beep when I press unlock on the fob.
Fault code shows up then (it was there when I got the car too):
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 18C000BC09000505485B090000D4
Shop #: WSC 00123 123 00123
VCID: 79FE75CB30CAF5F61A-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01179 - Incorrect Key Programming
000 - -
I am starting to suspect some other component is causing this problem when programming, other codes found:
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0140
Coding: 0000016
Shop #: WSC 06402 785 00200
VCID: 74E044FF17A8889E49-8020
1 Fault Found:
00100 - Drivers Interior Locking Button (E308)
008 - Implausible Signal - Intermittent - :rofl: button works but have to press it hard.
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P2 035 152
Component: Radio BNO 0031
Coding: 0020400
VCID: 67DA23B3567E7306FC-8032
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit - :rofl: FM reception is very good, is this used to receive keyfob signals too?
Probably not related - will investigate it:
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000003014852
Coding: 008C0F2700041000001E00000000000000007B0B5C
Shop #: WSC 00000 000 00000
VCID: 397EB5CB704A35F65A-806C
Subsystem 1 - Part No: 5P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 00000
1 Fault Found:
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Keyfob part no. HL0 5P0 959 753 C - 434 MHz - previous owner says it worked before, stopped working after changing car battery.
Thanks guys for taking time to read this :)
Dan
