You should see two slots where the keys fit in if you have the Aura CD system.
Push both in and the unit will pop out, pull it out completely by hand.
Then put your fascia adaptor in (for normal sized headunits) and then put the metal head unit surround in pushing it as far as it goes then use a screwdriver to bend the metal prongs down to hold the cradle in place.
Bang your ISO leads in, put key in, make sure all works, try tidy the cables behind the stereo just before you push it back in and voila your done!
