bloody_typical
45
Hi guys,
Ok, where to start..... my FR is now the proud owner of a new reconditioned engine and turbo, thanks to the failure of an injector (one which Seat have alreasy replaced), which caused overfuelling to a cylinder, wrecking it, and the chuck of piston head which broke away from the overheating took care of the turbo!
Anyway, car is now running like a dream...... once it starts. If left for more than 4/5 hours, starting up takes more than a couple of seconds of cranking before firing up. I can cut it straight off, and it'll fire up first time. It feels like a fuelling issue, but I'm out of ideas.
List of things done so far to try and fix:
- new fuel pump
- new fuel filter housing (apparently there's some sort of valve in there which had failed)
- new injector seals
- fuel lines all cleaned
Thoughts anyone?
Cheers.
When cranking engine and it doesn't start, does it sound like its struggling? As Crafoo said, could be the battery or check engine earth lead has been refixed
When the weather was cold mine used to take a few extra cranks and sound like a bag of spammers for a second or so once it had fired but a restart soonish after and it'd go fine - sound about the same?
Turned out to be the injectors that hadn't been setup right, only found out when I had it de-dpf'ed and Shark said they'd seen it quite a lot. It's because dealers were rushing the injector replacements and not doing it right sometimes.
Sent from my C6603 using Tapatalk
No, the starter isn't struggling at all. Andy550, what exactly do you mean re: injectors not being set up right? I ask because the injector for the knackered cylinder was replaced with the bottom of the block....
Sent from my HTC One using Tapatalk
The position/depth of the injectors in the head. They're pretty sensitive to misalignment and should be set with a micrometer. The main sign is the amount of smoke on start-up which the DPF soaks up. I had two winters of shite starts with mine until I had it de-DPF'ed and found out about it.
