2011 SC - is the door speaker fitted to the door or door card?
AlR
27
Hi all,
I've got an intermittently "buzzy" LH door speaker. It's as if the speaker is loose, and is rattling. Sometimes it seems fine. Knocking the door trim does seem to be quite rattly. Where is the speaker mounted? In the door structure or to the back of the card?
Have taken a card off before on another car to change mirror, this should be easier as it's electric!
Thanks in advance
dm222
1,470
46
Now an image
Sohail
16
Hi strange question but I was wondering if anyone has ever changed the door card of there Seat Ibiza’s. I need to buy a new door just for the shell, however on my existing car I have a manual window regulator and on the door I’m looking to buy it has a electric window regulator. So will the shells for both doors be the same and would i encounter any problems while changing the door card over ?
AlR
27
Just an update.
Took the time to take a door card off to see what was causing my poor speaker sound.
Some dullard / cowboy / butcher pevious to my ownership had "upgraded" the speakers but had used standard female spade connectors on the little speaker spades and as the speaker didn't fit the mount - had screwed it in with just 1 screw! Of course the speaker was now sitting across the mount rather than in it and the rubber diaphragm was pinched / split - hence my problem. Oh, one of the lower window regulator bolts was missing too, which caused auto close issues on the window.
So, a new set of speakers with correct mounts installed and proper connectors on the wires and the difference is astounding!
New bolt for the regulator solved the window close problem too.
Now I need to find an adapter for the rear body speakers ( SC not 5-door) and I might put some speakers in the back. This is the first car in 20 years that hasn't had rear speakers. I'm very definately used to the sound being all around. Does anyone have a source for the pins in the ISO connector and are they insertable?
