mungo
120
Southampton
Any ideas on this problem? Typically problems reared Friday night and can't speak to my mechanic until Monday, Car is meticulously well maintained. Mileage 85k, got it in 2023 with 45k miles. Last night on way home I felt a slight misfire that felt like it could possibly be coil pack related (I've had mk1 and mk2 Leon Cupras in the past, so know what it feels like). Then, waiting at traffic lights it stalled. Restarted. Weird rattly noise which then disappeared. Got home and opened bonnet - it would occasionally make a rattly noise, then stall. Restart - noise comes and goes. No dash warning lights. No errors reported on dash.
Any ideas what this could be? Typically, as I can't speak to my mechanic until Monday, I am worrying something serious. Trying to attach video to a link ... if anyone has seen this before / is a mechanic, would be grateful for any hint at what it might be
Update - cold start about 20 mins ago. Sounds worse, engine shuts down - engine warning light now on.
I will update everyone here when I get it looked at, I won't not put up the useful information like most seem to do after reporting a problem.
Reactions: mty12345
Get that on a proper diagnostics and don't start it again i say.
Could be running on just 2 cylinders by the sound of it.
Problem I have is I need to get it the 2 miles to the garage. What's concerning me most is the rattly on and off noise. Misfire alone and I would just assume coil pack or something, but the rattly noise is more than unnerving.
That's the reason why i wouldn't start it let alone drive, best to get it recovered.
Reactions: mungo
If you have engine warning light on the dash then there will be stored DTC Codes, what codes are showing.
Ok .... I DO have an OBD scanner and was lurking in my garage. I forgot I bought one years ago and used on my old mk2 Cupra.
Codes as follows ...
1. P0131 02 Sensor Circuit Low Voltage Bank 1 Sensor 1
2. P0303 Cylinder 3 Misfire Detected
3. P0304 Cylinder 4 Misfire Detected
4. P0300 Random / Multple Cylinder Misfire Detected
Sorry dont know the answer hopefully other experts will.
The P0131 is Lambda sensor related and I had to replace mine at just under 50k so thats a possible failure
Missfires have a look at https://obdeleven.com/p0304 gives you some things to look at and check.
Thanks, TT. I ran the codes through AI and it seems to think it's the coilpack now. Thing is, I had a Mk1 Cupra R (did 180k miles in that one) and a Mk2 Cupra, both remapped, and coil pack failures felt rough, but they never sounded as bad as this one - and so far I have kept my LC300 standard.
I am no expert but if it was coil pack I would expect P0351-P0362: Ignition coil issues, which might mean one or more coils aren’t delivering spark properly but not sure if those codes are generic or VAG Specific.
have a read of the document i linked to it shows you
Common causes of P0304​
The P0304 code usually points to these issues:​
Fuel system issues​
  • Dirty fuel filter
  • Clogged fuel injector on cylinder no. 4
  • Faulty fuel pump
  • Fuel rail issues
Ignition system issues​
  • Faulty spark plug or spark plug wire on cylinder no. 4
  • Worn or damaged ignition coil on cylinder no. 4
  • Incorrect ignition timing
  • Faulty distributor cap (on older vehicles)
  • Air intake issues
  • Vacuum leak in the intake manifold or vacuum hoses
Mechanical issues​
  • Damaged intake or exhaust valve on cylinder no. 4
  • Damage on cylinder no. 4 walls
  • Worn piston rings in cylinder no. 4
Circuit issues​
  • Crankshaft or camshaft position sensor problems
  • Faulty oxygen (O2) sensor
Other issues​
  • Poor fuel quality
  • Incorrect engine chip tuning
  • Malfunctioning EGR valve or clogged EGR passages
But I would stress I am not an expert in these matters
Reactions: Mo_86
Thanks mate, I guess we'll see when my garage looks at it. I'll show my mechanic the video before I drive it though, and ask if he thinks it's ok to drive to him.
I'll update here what the problem ends up being and cost of fixing etc - helps for continuity if anyone else has the same issue and comes here looking for an answer.
