nd-photo.nl
5,319
1,221
The Netherlands
youtube.com
Follow this guide if you need to replace (or check) the Camshaft Control Valves, also known as
- cam magnet adjusters
- camshaft timing solenoids
- camshaft variable timing valves
- N205 / N318
OE partnr:
06J109259A 06L109259A 6J109259A 6L109259A 06L109259D 6L109259D 04H973402A 4H973402A
Febi Bilstein partnr:
40198
Torque Specification T30 bolts:
9Nm
Generic steps
- Remove engine cover
- Remove electrical connector
- Remove 3x T30 torx bolts
- Remove camshaft control valve
- Clean surface / mating area
- Place new camshaft control valve
- Install 3x T30 torx bolt
- Torque to 9Nm
- Install electrical connector
- Install engine cover
Step-by-step video guide
Pictures:
AP1GczMePICHaL4GQCo0KTZYOF5qsPIRv1VDZNKQNWdDQ-aVtuka4DLrCtK1zhpAFZq1W-CKOWPqPISAnIO-inbXz34j0pu-5uhrQnZ3TcYcnYLWbFkI7K4hN0JTvKIbzwcCUObMvJR8rlTFoCMUWdtrGInjFw=w1920-h1080-s-no
AP1GczMLoM4v-j1AaHcnHJizxofvrtgAUVeTfYSRgj_OACWnjhxpnRd_9hjxtLA-OGDoh5iP29aCX-9QS2v5xGAHY0OIdxdA55OknCLbhXVnfAXHr_At9LrqDrqJgLzFVeQUUxJph6JJasd_ri-TTJNg2TyuMQ=w1920-h1080-s-no
