nd-photo.nl
5,319
1,220
The Netherlands
youtube.com
Follow this guide if you need to replace (or check) the belt tensioner (and serpentine belt), on your EA888 Gen3 2.0 TFSI/TSI engine.
The INA tensioner broke partially when I released the tension form the belt. Therefore I would recommend another brand, like the SKF unit I bought later.
OE partnr:
06K 903 133 ACSEAT
06K903133ACSEAT
06K 903 133 CSEAT
06K903133CSEAT
06K 903 133 ESEAT
06K903133ESEAT
06K 903 133 HSEAT
06K903133HSEAT
06K 903 133 MSEAT
06K903133MSEAT
06L 903 133 FSEAT
06L903133FSEAT
INA SCHAEFLER Fead Kit partnr:
534 0546 10 / 534054610
Not recommended: the captive nut is prone to breaking
SKF partnr:
VKM 31227
Belt:
6PK1132 / 6PK1130
Generic steps
- Remove upper part wiper fluid reservoir
- Unclip upper aircon line
- Remove tension from belt tensioner
- Put in locking pin
- Remove serpentine belt
- Remove 2 Torx bolts holding belt tensioner
- Remove old belt tensioner
- Install new belt tensioner
- Install 2 Torx bolts for belt tensioner
- Install serpentine belt
- Remove locking pin from belt tensioner
- Clip-in upper aircon line
- Install upper part wiper reservoir
- Top-up wiper fluid reservoir
Step-by-step video guide
Pictures
INA SCHAEFLER FEAD kit + Contitech 6PK1130 belt
AP1GczNPUcwuMyVHqkxbM-1Ec_GbNWdbsnRkdVOSeSrbI_rbdaSOwUMU71k8Xo00Tbr8yLIzcsPWsNZTsJH4NibBrE8Q_R7-a19VWTAseYobuTA9Mqu8VL2cxsKudIM5FeZrunGT9XKn9rvP1Q0iy7aX6FzYXQ=w1920-h1080-s-no
INA tensioner vs VW AG
AP1GczMpzg9opxij1I92UVKR7xA-dt76pSfPxsJYg6nEmb6Ul-NKKQbcVoztXEse_srxISge_U6HTLskD3XOgwz18-21_o9D5HoyQaqVDoD8djq6WBGI86zhWA6qUR-EAvDUvPDPUf_g8nuekS0oL6uAmBPtFA=w1920-h1080-s-no
Belt comparison
AP1GczMb28l3aqgpFx5Kz51JIdNEiZ3nsPmZzP3LtTYoCpFk9kfp9C-LKMIwongVQ2taa_wj7lfx02gZ6sS98gCyPEf768LC8uYF5xqVCBplPU4LpMjDPpMZmYv1fj9-_edEU_sY0ktrmfOYidLSWmk7VaRflg=w1920-h1080-s-no
Broken captive nut
AP1GczOOv4NdZZXP8ufF5HqBXWxnWvshxczyWMz_7-LzqfQh9OqwBpotfP13trhMLyhJbbWua7ler4QLHs_71seSb7q_m2luXq1USBgqYvXBsEzlN5SZKIOfyI41g4ag_B_QZkO5IlWHRhGdg48kRhc8G4tU9A=w1920-h1080-s-no
SKF vs INA SCHAEFLER (broken)
AP1GczN6k-CuwOcpeSLbXKqRR7ir9MCUYOw3pLLkQyi1654OTx51avokq5kUDmLmwr_TWqFM-zUIIJ2I5Sf7WQjciUjc0rRC6wOnLRL8lg5Se-lckog_pr6cvFgRhK_Mpx4aTJ6HIEynvMRn7AOmlZb8ETn-DA=w1920-h1080-s-no
Serpentine / Poly-V Belt Routing
Reactions: Mo_86
I'm just thinking out loud here, but how do you "wind back" the SKF version of that tensioner - as I can't see any thing on its body that is there specifically for applying a spanner etc to?
Edit:- or do you just use the pulley retaining bolt to rotate that part of the tensioner - possibly what some other tensioners that get used use to rotate the tensioner.
Correct, you use the bolt of the pulley, just like the OE tensioner. The INA has a separate captive nut on the tensioner housing. I used the torx bolt of the pulley to release the tension on the INA tensioner
Reactions: RUM4MO
It looks like the INA version would have been more robust "in this area" if they had left out the provision for using a Torx bit to rotate the tensioner - nice and convenient idea, but not fully tested to see if it did work!
Reactions: nd-photo.nl
Exactly, I had those thoughts as well. It broke when I tried the torx part of the captive nut and then it just snapped on me :blink:
