nd-photo.nl
5,319
1,221
The Netherlands
youtube.com
Follow this guide if you need to replace the brake booster hose on your 1.8/2.0 TSI Seat Leon MK3.
Generic steps
-Remove engine cover
-Remove intake pipe
-Remove vacuum hose
-Disconnect pressure sensor
-Remove brake boost hose
-Optional: swap over brake pressure sensor
Reverse steps above
Partnr
5Q0612041AR
Why replace?
My Cupra was fitted with a cutout valve in the exhaust, which is operated by vacuum. Someone decided to tee-off from the brake booster hose, which is a big no-no in my opinion. If you would have a vacuum leak, then the brakes are compromised, which has severe safety implications. In the end, I ran a vacuum hose from the intake plenum (via the MAP sensor).
I replaced it with a 2nd hand unit, but decided to replace the pressure sensor, as I know the existing sensor was working fine.
Step-by-step video guide
Pictures
AP1GczPa3P_hTJw839FiEhDIoDYA3JakLwycCU9gs-R3t2blWyiJh9Mn_XzOubybqTJmtnwKZaJIKQbm3FtQGMNmHPXq5G97LRmAqdDe-r6iI2Wd_3BvwM8diE2AVchztNPrmPW67v0fIr6HP4F4I9fEX4-3Mw=w1920-h1080-s-no-gm
AP1GczMfxEMbFLxcaKPVtFAaVPJr-IEOIBtBM3ZyCB83KOUa4uT9SbCmdHOuT5oB-mexo99dBlB0UyT0hUWY3-O-u-Ke_nNhhhqxwkIjPaVQ_XNxVo8EEhV_Dc1m2HNMjRDpQ6ma6vRVVmVgvSc8PtzWACkSTA=w1920-h1080-s-no-gm
AP1GczMFv8Jw3aGqSHeSvuvp1MsMy_DiSnJqevhdDnBh0mVeUgAZ6zY56sn1O34owaZalrAVPs38GFTSj1-7GHkN5hbQ11Lo5bkPnFcc6UetUqWfPUaqyt26aVKo6SNU23fRuk51hCV3k2c40XJ1GGrC-TcKtQ=w1920-h1080-s-no-gm
