Here's a few pics - invisible behind the trim but when you lift it up, it's like it was always there too :)
Reactions: bigT's lcr
Which strut brace did you go for paddy? Im contemplating one for my family wagon :cheeky:
The facebook special haha Sold by a guy called Ian Frazer on the facebook groups. Went from a group buy discount to him ending up being the UK Supplier for them. £85 I think they were.
And they are worth it ;)
is this a cupra group or a general seat one?
Does Ian have a web site or does he use Faceache as his shop window? I dont do faceache but I can use the misses facebook account if needed to reach out to Ian.
Are these easy to fit? Is it a case of fitting underneath the existing bolts? Access seems to be the biggest issue?!?
Original instructions say to remove the wipers so you can take that black plastic panel off. However I did it without taking the wipers off and leaving the black plastic on. It was more fiddly obviously, but no more so that trying to rip the wiper arms off without damaging them or the bonnet.
how did you code these in?
with VCDS or OBEleven?
  • Auto folding mirrors with lock
  • Auto fan speed display with Air Con
  • Disabled open door alarm
  • 5 flash 1 touch indicators
Hummm looked all over VCDS (genuine copy) can’t find the 5 flash soft indicators
Maybe need to buy the Hex-Net and it can’t be done on the older Hex-V2
Have you tried this:
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Control of intermittent
4 - Sub - Komfortblinken blinkzyklen
5 - Change to the desired value - Maximum 5
6 - On the car infotainment screen, reset factory settings for the lights section.
