Model Year 24/25 2024 Cupra Formentor – Rear Light Warning Keeps Popping Up
Feb 18, 2025
I've owned a 2024 facelift Cupra Formentor for about 2 months now. The car hasn't even reached 1000 km yet, and I'm already experiencing a strange issue.
One day when I started the car, I noticed a warning light on the dashboard, along with two messages on the multimedia screen:
  • “Check left rear light”
  • “Check right rear light”
Both messages appeared at the same time. I pulled the handbrake and checked the lights without turning off the engine, and everything seemed completely fine. When I turned the car off and restarted it, the warning messages disappeared. This same situation has happened 4–5 more times. Each time, the messages go away after restarting the car.
I took the car to the Cupra service where I bought it. The technician there told me that new models have a lot of sensors for control purposes, and sometimes they can show false warnings like this, but that there was nothing actually wrong with the car.
However, after seeing the warning again even after the service visit, I’ve started to feel frustrated — especially since this is a brand new car.
Has anyone else experienced this kind of issue? Any advice would be appreciated.
DaveSmith
50
25
Market Rasen, Lincolnshire, UK
It happened to me once for one of the turn signals. As in your case, once the car was turned on and restarted the warning went away. It has not reoccurred as yet. Not at all sure why it does it. The engineer in me suspects that some algorithm for picking up faults on the CAN bus is maybe a little too sensitive.
cairus
1,603
559
The individual lighting channels are monitored for cold and warm. The BCM control unit is responsible for this...a sensible start would be to read the error log with a reputable diagnostic tool and report it here.
Napmasterflash
260
156
I had a 2021 Formentor for 4 years and I used to get random messages about various rear lights not working plus park assist not being available etc. I flagged with Cupra numerous times and it never really got sorted but would always reset after I restarted.
Weirdly, my wife who had the memory seat in a different position to me used to get way more warning lights. I can't see how the 2 could be linked but definitely worse for her.
william griffiths
7
I have this happen quite often, spoken to CUPRA and apparently it’s a common fault with the facelift car, software issue apparently and they’re working on an update, but don’t hold your breath on that one! , I tend to just ignore it until I restart the car again then it goes off. V3 2025 model.
