205/45/17?
sheep
62
Oxfordshire
does anybody know if i can get away with putting 205/45/17 without it rubbing on rather then the 205/40/17. im currently running 215/40/17 but these rub and have been told that they are rubbing as too wide.
Id prefer the 45 option if i can put these on without rubbing so it a bit of a smoother ride and also the roads round here are bad with pot holes.
I have tried searching but couldnt find anywhere to see if 205/45/17 rub or not?
Random1989
FR MAD
Feb 9, 2010
555
cleckheaton
i'm currently running 215 35 18 and there fine and next i'm going to try 225 40 18 back wheels are spaced so will be fine and front will be spaced if i get any problems but think will just get away with it
oh i cant compare really because my wheels arent standard sorry
Chris_a_73
1.2L Ibiza Mk4 '07
Oct 27, 2009
1,949
Guildford and Bristol (uni)
Mine aren't standard either :p
But like I said before, a consistant rolling radius should be used! By increasing the rolling radius you'll be putting further strain on the gearbox and also put the speedo out by several mph.
VWscooby
288
Durham
Random1989 - I wouldnt try 225/40s! I have been running 215/35 18s for the last two years with no problems or rubbing at all but had to run 225/40s while I waited for some more low-pros to come into stock. Im down 45mm and they rubbed EVERYWHERE!!
I am running 8 inch wide wheels with a 35mm offset if that helps.
