Sany20Vt
anyone knows what the gear ratios on the M6 box?
my car is 2005 20vt leon
thanks!
Sany:confused:
M6 ? I can look em up if you know the actual trans code at all ?
ERR / EFF / ERF etc
also as it's 2005? def last of the old shape ?
chee man you are quick.
I dont have the tranny code.
and im not sure what you asked me by def last shape .
thanks
:blink:
Sadly the chassis/Vin only tells us it's a Seat vehicle and what factory its made in along with its unique ID number.
there is sometimes a spec sticker in the boot that will list the engine/gear/colour codes
old shape model looks like below but if you can tell me what model car it is Cupra/Sport/Cupra R or just the BHP I could get somewhere close
ok so my car model is 2005. it is the mk1.
in israel its knowen as leon fr in this year model
my engine model is ouq with 180 bhp
please help :help:
From the year and model it appears to be an FZQ transmission although the casing should be stamped if you get chance to confirm it
Rev - 1.64
1st - 3.36
2nd - 2.09
3rd - 1.47
4th - 1.15
5th - 1.25
6th - 0.98
diff ratio on 1st pinion set (1-4) 3.94
diff ratio on 2nd pinion set (5-6) 3.08
(i think thats the right way round) :)
if it's a different code let me know as it's an israel car and may be imported with diff specs etc etc
not found one online yet but there's a few bits of info about here and there to download but if you know the trans code i can look em up for ya
should put em in a spreadsheet really but there's shedloads
Interesting.... How about my -04 LCR? 6 speed manual.
210 ? 225 ?
or better still do you know the trans code ?
-04 LCR 225BAM... have no idea about the code... I know I have a 3rd gear grind when cold so I need as much info about that box as humanly possible.
FZQ . . . 6S . . . 05/03>> . . . 1.8 . . .165kw . . . 225bhp . . .4cyl
looks favourite to me
Final Drive 1 (1st-4th) 71:18 = 3.944
Final Drive 2 (5/6/Rev) 71:23 = 3.086
1st - 47:14 = 3.357
2nd - 48:23 = 2.087
3rd - 47:32 = 1.469
4th - 46:40 = 1.150
5th - 43:36 = 1.194
6th - 39:40 = 0.975
Rev - 34:14 x 23:14 = 3.990 (pass)
capacity 2.3 + 0.1 litres
been told by a gearbox reconner that when they start to get nasty to change gear the rear pinion bearings need changing at about £3/400 but if they have already started leaking then it's a full overhaul
not had pleasure yet thankfully
great tnx !
Mine still changes gear smuuth but when cold it makes a grinding noise in 3rd when off power. One box specialist say its a bearing and it needs a complete refurb were another vw mech say just drive it until it brakes. Sooooooo......
great tnx !
that sounds similar to mine does in 6th - vibrates when you let off the power.....may be a little worried about this now! haha
