340mm 09.C306.1X Drilled Brembo Discs
BigJase88
Jase
Apr 20, 2008
3,767
1,069
Drilled are pointless i ran them with 4 pot brembo lcr mk1 calipers, all they do is apparently dissipate heat better and crack between the drill holes :drive2: stock brembo discs would be a better option if you are due a replacement
Kirky
Copper Cupra Advocate
Apr 10, 2019
1,042
497
Dissipating heat better on a metal disc isn't pointless as heat is what causes brake fade. Better heat dissipation even makes a noticeable difference on my MTB let alone a car. They also perform better in wet conditions as it's harder for the water to build up between the pad and the disc.
I'm aware of drilled discs cracking but wanted to know if anyone has any experience with this exact model of disc. If it doesn't crack super easily then I'm interested.
Reactions: WeAreWolves
CUPRoAr
69
16
Like the look of these too. Have you found anywhere that actually stocks them? If they aren't too much of a premium over blank discs they are worth a go.
Kirky
Apr 10, 2019
1,042
497
I think they may be new as last time I checked Brembo didn't do drilled discs for the VAG cars in 340mm. Maybe the reason I haven't got many responses.
I'm going to ask europarts if they can can get hold of them and at what price.
CUPRoAr
69
16
Ah fair enough, let us know how you get on.
Mar 12, 2020
Mar 12, 2020
Let me know if you get them. Im still looking for these exact ones and the Xtra pads to go with them,also the 310 mm rear drilled
Invertigo
169
77
Drilled rotors in road cars are largely there for aesthetics only, even race cars very rarely use drilled instead opting for C-hook disks these days. Yes they'll drop heat a bit quicker, but they're also more likely to crack if you do get them hot. They also make more noise than smooth disks, another thing to consider.
If you want better braking, upgrading the pad compound is the best option.
