5 flashes of yellow oil light
ozaudio
387
north west
From searching im guessing its probaly a sensor? i also noticed under neath the car a plug was unpluged from the sump which ive now plugged back in, i have checked the oil and its fine so im guessing the previous keeper unplugged it as its just faulty?
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
The oil warning lamp has several different indication:
Flashing or steady red plus three beeps: low oil pressure.
Steady amber: low oil level. Stop and refill. Opening bonnet resets the oil level trip.
Flashing amber + beeps: oil level indicator fault
Flashing amber means a problem with the oil level sensor system. The sensor itself is the thing you've just plugged back in. There is also a microswitch in the bonnet catch, right at the front of the bonnet, which resets the oil level warning. Check this switch to see if it's OK.
This picture of my old Toledo with the bumper off shows the lock in all its mucky glory. The microswitch can just about be made out under the near end of the spring.
Obviously red means stop, stop the engine and find out why you've got low oil pressure. Continuing to run the engine will cause bearing failure. Steady yellow means top up the oil.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
You need to find out what's wrong. Sensor could be faulty, the plug that you reconnected could be faulty or just dirty after being loose under the car, the microswitch could be faulty, disconnected or have fallen off the lock plate. There may be more information available from fault codes, so some help from someone with VCDS could be useful.
Your profile says you drive surprise, which is not helpful. What car are we talking about here?
