haphazard
Hi All,
I recently bought my MK4 53Reg Seat Ibiza 1.2. However I forgot to check reverse lights ( do you ever check lights when you buy a car?). I managed to take the left rear cluster out and changed the bulb attached to reverse light socket and it did not work. Then I thought it might be a fuse issue and checked the fuses but that did not help either.
Has anyone experienced this problem before? I made search on google and came across the same problem yet it was for MK1 Leon and telling to change the switch. If you know where to find the reverse light switch on MK4 Ibiza's, that would be much appreciated.
Thanks.
Thanks.
