Pyro
This is a very rough guide to catch tank fittment
This is the initial set up well mine any way
the pipe coming from the to inlet of the tank goes into the tip where the hockey puck was (remove hockey) as show here then you need an elbow into the tip witch is in the second pic
Then the pipe from the bottom inlet if the tank goes into the crank case and also T's off under the inlet manifold and joins with a metal elbow that come out of the engine as shown in these pics
Then take the pipe of from the inlet manifold and put a small pice of silicone in place and blank it off with a plug or bolt and make sure it's tight or you'll get a boost leak!
birds eye view
Sorry the pics are crap but hope it helps if you need any more then let me know.
Sam
P.s hope it helps Mo
Sam
