worse on the drivers side
passenger side starting
That rust is from where someone has attempted/succeeded to break into your car with a metal coat hanger. Seat will not pay to repair that.
WRONG - i can bet every mk4 Ibiza has marks there (mine does, just no rust) its from the rubber seal rubbing the paint work, nothing you can do about it eitha
I used some of this:between the front wing and the sill. (I've not found a cure for these yet )
http://www.ebay.co.uk/itm/CAVITY-WA..._Body_Shop_Supplies_Paint&hash=item3346fc4b3c
it comes with flexible nozzle and hasn't washed away in the year it's been on my car.
Also done all the body panel joints out of view.
Got any pics of what it looks like when it's in the gap? Want to prevent mine from developing this problem
It's not something I'd take a picture of it looks like candle wax but sticks like **** to a blanket! Get clear stuff though
Lol. Got a fair idea what it's like - Waxoyl. Think i'll invest in some.
My 3 door 20vT MK4 never had those marks.
Both wrong. It's a join in the paint. Nothing to do with cost hangers or the rubber.
Explain???
Any paint jobs I do.. I blend one over the other so there is no "join"
It is where the rubber lip from the rubber seal is rubbing on the paint .. you see on every high mileage car as the doors wobble around and this fretting wears the paint. Thin paint makes it more likely to happen. Buying new rubber seals will not change it. Wax of some sort does a short term fix; repainting and then keeping car waxed and clean is the long term solution but not cheap.
You didn't paint ibizas in the factory though
My car, and others I've looked at, had that line from new. So it's nothing to do with the door rubber.
Explain???
