Abs, Traction Control and Tyre Pressure
Jun 28, 2025
Hi all,
I am having issues relating to my Traction Control, ABS and Tire pressure lights.
I have an obdeleven scanner and diagnosed the rear right sensor, but having replaced it the problem partially improved but moved to the front left.
Does anyone have any ideas?
Ps, I also occasionally get an error on my dash saying Start-Stop error, potentially related?
Jun 28, 2025
The problem always occurs after starting? Have you checked the power supply warning?
It usually happens after starting, it used to turn off with driving for a few minutes but now stays on permanently.
I have checked all the fuses in the box beside the battery and found nothing wrong there.
Jun 28, 2025
The warning concerns the battery itself. Have it checked
The battery is healthy when testing with a multimeter, the light also regularly stays on for the duration of the journey.
Where is the BCU located? Perhaps there is corrosion?
cairus
1,582
552
What voltage does the battery have during startup? Otherwise, you'll need the circuit diagrams. I don't think all the sensors are defective. Do a log run with all four sensor signals and KL30.
Jun 28, 2025
So with my battery the meter says a minimum of 9.3v at starting.
The lights have disappeared from the dash since removing and reinstalling my battery but refuse to clear with obdeleven.
Find the charts attached below, I couldn't upload CSV so I compressed them.
  • Charts.zip
R3k1355
1,872
275
Yorkshire
A duff battery will give a host of weird and wonderful error codes that are completely unrelated to the problem AND will randomly change with no rhyme or reason.
Replace the battery.
(I got my last Ibiza super cheap because of this exact reason, previous owner had spent a fortune chasing false error codes)
Reactions: lb2419
