cupra_jobe
158
Just fitted my new brakes and went for a spin after a quick blast i can hear a leak from some where i have a split in the actuator arm seal. Cr have told me it needs replacing but it hasnt been a problem in the past. Now when i boot it there is a leak sokme where and judders like mad. Is the actuator or maybe summin else.
Also have noticed the front engine mount is snapped whats the best solution?
Am guessing bill again! cheers peeps
Did CR supply you with an uprated actuator? As for engine mounts, Vibra-technics from Badger5 would be the best bet. Last thing on my shopping list before the turbs gets fitted
yeh ideal no put the standard ine back on beacuse of 2 port or 3 port and they didn t no if it would fit so i dunno really haha
do you rekon that is the probelm though cant see any leaks any where and is all fine on idle when reving just when moving obisly more pressure
