Actuators
T7ODD
Hi,
I'm unsure if a lot of you remember my missing boost problem. Will at P-Torque kindly checked the ecu programming again on the map and couldn't find a fault but uploaded another map he did for another Ibiza which was proven on a rolling road. I put the ecu back in and sadly only saw a minor increase.
After the original remap i went from a standard 8/9psi to a 10/11psi. The map was requesting 18psi. The new map requests 21psi peak like Revo but I now see 12/13psi WOO HOO :lol:
A couple of mechanics have ruled out boost leaks
I've changed N75 valve and logged MAF which seemed alright.
Checked DV.
Wondered about blocked cat but it recently passed MOT emissions.
All I was left with was still a possible leak somewhere, actuator, or cracked turbo even though it sounds fine.
I saw an ex-Ibiza Cupra owner who looked at the actuator and said it was wound in too far and asked if it'd been touched. I said no.
From the end of the rod to the first nut there are 17 threads, to which he said his used to be on 11 as he'd experimented loads with his as it had had a new engine. He also said that all other Cupras he'd looked at were between 11 and 13 threads. We wound it back out to 11 threads. I made my way home. Pickup was very slow and boost was down. I wound it back in a bit more to 13 threads to which pickup was better and boost was back to 12psi. I decided to put it back to where it was originally at 16/17 threads which is nearly as far is it goes on the bar. The car is back to boosting harder again at 13psi but still missing my boost.
If my actuator is faulty, would it be able to manage that extra 1 or 2 psi between the two different maps i.e. requesting 18 and 21psi ???
Maybe my actuator is weak and has been wound in previous to my ownership. Car was only 2 years old when I bought it and i've had it 3 years)???
If it's not the actuator at all and there is a leak somewhere, will be turbo work the same amount sucking the same amount of air through the intake giving good MAF readings? I'm unsure how it works.
I'm very confused! :confused:
Can anyone take photos of their actuators for me out of interest??
bgasmatt
82
dut a forge actuator blue spring m8 she will run fine
ps the tuners tell you have to take the turbo off its not true just manifold and oil flow to turbo.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
have you checked applying pressure to the actuator to confirm its opening at ~5psi ?
pressure pump it up slowly and see when it cracks open.. and if it holds pressure.
internal leak blowing by wastegate would leak you some boost, and could a fecked (tech term) impellor which is rolled its comp wheel edges over..
N75 duty cycle should rise as its "trying" to achieve requested boost.
quick check of turbos ability to boost is clamp the N75 pipe to actuator so it cannot open the wastegate and go for a "controlled" drive easing on the throttle and load and seeing what boost it can manage. If no more than what you're getting now, its very likely mechanical turbo knackered.
I have seen this previously, on remapped mk4 golf... did not boost no matter what you did. Turbo was dead.
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
T7ODD posted this in July 2007 and sold his cupra last year - i dont think he'll be checking this! Although Bills post should be put in to the FAQ bit
