All,
If you didn't already know, my car has been off road for over a week now and it's been diagnosed with the following problem
1 Fault Found:
001139 - Exhaust Pressure Sensor 1 (G450)
P0473 - 006 - Signal too High - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 1
Fault Frequency: 50
Reset counter: 40
Mileage: 64879 km
Time Indication: 0
Date: 2000.00.00
Time: 10:27:05
Freeze Frame:
RPM: 3584 /min
Torque: 296.0 Nm
Speed: 62.0 km/h
Voltage: 14.35 V
Mileage: 120 km
Text: 628 C
Pressure: 1938.3 mbar
Basically for all of you who don't understand it, I will explain. The 2.0 TDI 170 is fitted with a Diesel Particle Filter (DPF) and is a right pain the ass. There is a lot of issues with peoples DPF since the injectors have been replaced and therefore I got a funny feeling this sensor is something related.
Anyways - the sensor is also known as the 'Exhaust Pressure Sensor' and it monitors the soot levels within the DPF. As this sensor is now faulty, there is way to tell how full my DPF is and the more I drive it, I could cause it to block up and cause my car to run into further issues. Once a DPF reaches 91% it's written off as it cannot be regenerated as it could potentially catch fire and costs £1,200 to replace. Absolute ball ache yeah?
I am wondering if anyone has any experience and knows how to adapt the sensor via VCDs? I have been let down by numerous garages this week, car is sat on my parents drive and I am going away next week! Great! I need to get a new sensor myself now, fit it but before you can even start the car - you need to adapt it to the car to ensure it's reading the correct soot levels.
send me your email address via pm and will send info for regen
when you fit sensor you blow down vacuum hoses to make sure they are clean and do forced regen
you dont need to adapt
done several
