Adblue.
Rampage
Trainee Northener
May 24, 2003
1,035
I am away on holiday and the Adblue warning has come on. I wo t be home before the countdown runs out.
Can someone remind me what the manual says please. Do I just put in 10 litres then that’s it?
Thanks.
Rampage
Trainee Northener
May 24, 2003
1,035
I’ve bought 10 litres, but isn’t there a certain amount I have to put in or a procedure or something?
Thanks.
timhowarduk
8
You should put in 10 litres minimum. Turn ignition on for 30 seconds, then start engine.
I sincerely hope that is the end of the matter for you. Is message "Check AdBlue" or "Topup AdBlue" ?
If it doesn't clear message after topping up, then post again, and I'll talk you through the fun I had.
Rampage
Trainee Northener
May 24, 2003
1,035
Hi, yes it worked fine thanks.
I’d read something before about someone having problems so maybe it was you?
