offitmassive
18 is the y piece here
looks more like an upside down, back to front F at the centre of the image
this is correct. the hose with the one way valve stays as it is, the other out let gets blocked off.![]()
This is one of the one way valves i was talking about the other is closer to other end of this vac pipe
are these any good? what size do the joiners on the catch can need to be?
http://cgi.ebay.co.uk/POLISHED-OIL-...arts_Vehicles_CarParts_SM&hash=item5d2e7ce0d1
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330521993834&ssPageName=STRK:MEWAX:IT
stu
stu
You guys do realise that 10-15mm hose is way too small. The engine uses 19mm hose for a reason, if these hoses are too restrictive there will be pressure build up in your engine which can and will cause damage.
