Advice please on engine fault
DaFoot
299
Sheffield
www.dafoot.co.uk
This is the state of my dash at the moment :(
2L Diesel.
Noticed a rattle/knocking noise from exhaust area when starting car at the weekend (from cold).
I opted not to drive it since then.
So I went to get more info just now and current state:
- engine turns over and starts ok
- first time (cold) I initially got a message about an issue with the adaptive cruise control
- after a few moments the engine cuts out leaving those lights on (the yellow ones I'm bothered about ;) )
- try it again and it starts ok, but after a few seconds, or perhaps if give it a little gas, it cuts out
The 'coil' light is flashing, not solid.
According to the manual, that means:
"Fault in engine management"
and
"Fault in emission control system"
The second one fits with knocking noise from exhaust area I guess.
Can anyone offer any suggestions as to:
- what the actual problem might be (educated guesses welcome)
- single issue causing both problems?
- likely cost
- am I going to have to take it to SEAT (there's a franchise a mile away) or will a local garage do?
Mr Pig
2,905
1,084
A local garage should be able to read the fault codes for you.
Zaco95
132
8
Bury St Edmunds
Find a local VAG specialist go there get them to read it and quote you, they shouldn’t charge much for a fault find.
Or like was said previously get yourself Carista or I use OBDEleven to read the faults yourself if your happy doing that.
DaFoot
299
Sheffield
www.dafoot.co.uk
It's at an independent SEAT specialist now.
They've found 'swarf' in the fuel line. So it's gonna be a big job :(
I wonder if that's a symptom of service being overdue (so fuel filter/pump degrading) ?
